Season 12 endgame isn't really about "one big grind," it's about picking the right grind at the right time. You're chasing Opticide for Masterworking, then you're broke again, then you're back in the loop. If you want to speed things up, treat your route like a shopping list, not a ritual. And yeah, if you're tweaking a build while you farm, it helps to know where people are trading and browsing Diablo 4 materials for sale so you can compare what's worth hunting versus what's worth skipping for now.
Opticide without the endless Horde spam
Most folks default to Infernal Hordes because it's familiar. It works, but it gets old fast, and the Opticide per minute starts feeling rough. The Undercity is the play this season, especially if you can run Torment 4 comfortably. Pop a Tribute of Refinement and you'll see a noticeably fatter Opticide return than the usual 6-wave Horde cashout, and the runs are quick enough that you stay focused. The best part is you're not just farming a number. You're also narrowing in on specific Legendary aspects, so your time isn't "materials only," it's progress in two directions at once.
Nightmare Dungeon hits you don't want to ignore
Nightmare Dungeons still matter, just not as your main job. You're basically fishing for the special rooms and the rare dungeon events that swing the whole day. If you spot a Horadric Strong Room, it's worth doing cleanly instead of rushing past it. And if you roll into a Treasure Breach, stop whatever routine you're on and finish it, because that Opticide spike is absurd. It's the kind of payout that saves you multiple crafting sessions. Outside those moments, don't force NMDs. Go back to fast Tribute runs and keep the pace up.
Fresh Meat, boss loops, and the Pit 100 wall
Fresh Meat is where a lot of players waste time. If you're gambling for Bloodied pieces, you need big chunks of it, not drips. The Broiler's Lair is the cleanest loop: a normal kill is fine, but the Bloodied version is where the stash actually fills. To keep those sigils coming, turn in your Reputation Caches and don't be shy about doing 6-wave Hordes just to top reputation back up. Also, be ready for the post–Pit 100 reality check. Once you're in that Blood Soaked tier, efficiency drops hard if your build isn't cruising. Farming sigils on an alt and moving them through stash sounds goofy, but it saves a ton of failed runs and repair bills.
Keeping the grind sane when you're gearing up
When Helltides start feeling slow, it usually isn't your damage, it's your grouping. A Godslayer Crown can fix that vibe immediately, and pairing it with easy crowd tools like Penitent Greaves on Rogue or a Necro aura setup keeps packs glued together so you're not chasing stragglers. And if you'd rather smooth out gearing between sessions, there's nothing wrong with using a reputable marketplace either. As a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy diablo 4 runes for a better experience while you keep your actual playtime focused on the farms that pay out.
